water/meth?
water/meth?
I have been thinking about geting water meth for my 01 dodge...does it really help and is it hard to hook up?...which brand would be the best for my setup?
thanks
thanks
i have a stage 2 kit from snow performance and i love it. pretty easy to mount up just in my opinion the control modual needs to be in cab to keep in dry safe place.
where would be the best place to get that...i know i can go to snowperformance.com or w/e but didnt know if you knew of a better deal...i have heard of some guys running windshield washer fluid through theirs...is that safe...and does it still work the same as the bottled stuff they want you to buy?
i bought my kit thru summit racing.. no matter where you buy it you only have to have the reciept to get any warranty things done.. which you can fax to Snow or if you buy it direct from them its already there.. Yes you can run washer fluid.. if you check snow performances forums there are threads saying what kids you can run.. but for the most part the Wal-Mart brand of -20 fluid without any cleaners or solvents in it will work.. Techsomething or other is the brand name.. i purchased the stage 3 kit which also reads your EGT's and at certain gain levels it injects certain ammounts depending on your EGT's and Boost.
where do you install that nozzels. i have the banks air elbo. can i tap that to run my nozzels. i am getting it for christmas from my girlfriend. what a girlfriend.
i happened to have bought the ATS Arc Flow intake elbow before i even thought about water meth.. it comes pretapped for boost/water meth/propane/nos.. whatever you decide to put on there.. comes with 4 pretapped holes..
ya i know that but i bought the Banks and didn't think i was going to do water/meth. can you also put Nos with water/meth.
yea it is.. but thats because the heat mat or w/e it is.. that black stuff is hanging down.. imma do something about it eventually.. lol for the moment i could really care less. since its not a hot pipe...
yeah all this sounds good to me...so the only difference in the stage 2 and stage 3 is egt?...or is it better..because i already have a egt gauge...also does it add any dyno hp?
