Water meth
Water meth
From my searching I realize that water/meth increases cylinder pressure. Can I just run water? Not looking for more power, just egt reduction.
Thanks,
Josh
Thanks,
Josh
The meth is going to start igniting far before TDC, so that's where your big spike in cylinder pressure comes from. The water is just for cooling. You bet you can run just the water. I'm sure you'll have to tune it in a bit, but it should cool things down a bit.
Agree. Regular washer fluid is only 20% meth... and it's not like racing meth. It's very mild.
I have run straight water in the past. It works, but you have to hold off injecting till a higher boost level.... to avoid quenching! Should not be a problem with your twins!
With washer fluid I have no problem starting injection at 18 psi; would probably want 25 psi for water only.
RJ
RJ
more of a technical question
I have a stage three snow performance kit, so I have a second pyrometer just for the water meth kit, well, I got my truck detailed yesterday and I get in it this morning and I happened to notice the water meth swith was flicked to on... the egt guage for it was reading 1200 at idle or engin off with ignition on. and when I did start moving and my egts were at 700 on my other pyro the water meth guage showed 1600 or better and started injecting at 100% power.. this queched and cholked my engine.. I checked the connections for the pyro and they are good the whole way.. *** happened?? did the detailers ruin a 700$ kit? or should I install a new egt probe and see if that helps? they cleaned the truck inside and out including the engine compartment.. but the other pryo works fine.. I'm lost and ****** off..
hey Jambbii, don't know if you remember, but I am running straight water and it works fine. I have heard that the meth content should not exceed 50% and that is pushing it. 40% would be much better, but the benefits far outweigh the drawbacks
but to answer your question.....you can run straight water just fine.
My kit activates at 20psi, I experience no quenching or stumbling and is smooth all the way up....I could do some runs tonight with and without the water and compare the temps
Try attaching the snow controller to the egt guage theromcouple to verify whether your problem is in the theromcouple or controller.
i don't have a Ktype egt probe for the normal pillar guages so i havent connected that egt probe to the snow controller unit.. I called snow performance and Nate is sending me a new EGT probe, should be here next week, i'll install that and if it is still reading way off like now then it has to be the controller unit.
jdpiii
06-19-2008 07:34 AM
mcevins
05-13-2004 05:36 PM
