Water Cooled HX40
Im getting some flanges made by a local machine shop pretty cheap and going
to neck down a piece of 3x2 i.d rectangular tubing to connect the two flanges.
And i was thinking about bringing the water out from the plug between cylinder
number 3 and 4 on top of the head. Then returning it to the heater return line.
Is yours a 17 cm housing?
I would use the exit off your tranny heat exchanger. There is valve that limits hot coolant from going into your heater so you can have air conditioning. With the valve closed, your not going to get any coolant flow. I remember seeing a kit that Cummins sells there generator or heavy trucks that ties into the back of head and help move coolant from the back #6 cylinder. Thats the best fix for the engine and turbo, you might have to do a search on the site to find it. Whats the part number off your turbo? Is the coolant going into the bearing housing or goes into the exhaust housing?
banks twinram
05-01-2011 05:34 PM
Hawkeye
09-23-2003 09:22 PM
