water conversion
water conversion
I bought a cd rom that tells you how to run your truck on water. The system seems fairly simple. They say it can be done on a diesel. The process pulls the hydrogen out of the water molecules by way of electrodes in a generator. They claim that one gallon of water will supply enough fuel to mix with diesel for one tank of diesel. It is suppose to improve mpg by 45%. The by product after it is burnt is water vapor. The only problem they say with that is that the valves need to be stainless and same for the exaust pipe to keep it from rusting. any feed back or ideas on this would be great.
Do a search for Hydrogen or HHO on the site. A lot of discussion and the bottom line is basically "you can do it but the advertisements are just that...." Search YouTube for the same thing to get an idea of what the process is....
Hydrogen is a very high energy fuel. HOWEVER, the quanities that you can split out of water with an on-board system are insignificant. The additional load on the alternator (and the attendent torque required to turn it) exceeds the energy produced by burning the hydrogen. TANSTAAFL
LightningMqueen
04-24-2007 09:57 PM
RamWheelsBy4
04-11-2007 05:43 PM
Gene Peterson
01-07-2006 03:32 PM
