wat to stack with tst?
just bought a tst for real cheap. am wantin to run it but know i need somethin down low. wat should i do. ez, smarty, powerpuck??? thanks
I had the tst, ez, an smarty stacked on my last truck. Worked very well together. The ez gives fuel down low, an thats it. The smarty gives it down low an mid range but increases timing more an makes it funner to drive because it has much better throttle response.
Run your comp as Redliner said with the wiretap unhooked. I've tried everything with my TST including the old catcher programming which was the predecessor to the Smarty. I lost power on the topend with the catcher tunes. And make sure the TST you purchased has the competition tune in it. The TST comp fuels very hard and very aggressive so don't be alarmed when your truck shakes when you let off the throttle on settings 6 and above.
Do you fellas know how much top end pull/power you lose with the Smarty over the EZ stacked with the TST? I'm planning on getting the TST in the future (comp version hopefully) and will be stacking with my already have Smarty. Would it be much more of a benefit to get the EZ or run a Quad XZT+ with the TST?
lvmknsmoke, hopefully you don't mind my question.
It goes map sensor to tst, tst out to edge box in, edge box out to stock harness. They MUST be all hooked together. Just tap the pump wire with the tst box. The only thing you wont be using on your comp is the pump wire. Go to tst's website for the instructions to hook up the other wiring on the tst.
p0wd3rp1l0t
10-15-2009 02:18 PM
jeffreystewart
17
05-22-2009 01:13 AM
Topper
03-03-2008 10:17 AM
bzackrie
Competition / Pulls / OffRoad
01-26-2007 11:14 AM
