Wastegated housing or not?
Old 09-13-2004 | 03:12 PM
Jambbii's Avatar
I am looking to upgrade my housing to a 16mc2 and I am wondering if I can run a non wastegated housing? What are the pros of cons of wastegated and non wastegated. Wouldnt a non-wastegated housing eventually blow up my turbo?
Thanks.
Old 09-13-2004 | 04:56 PM
Forrest Nearing's Avatar
not if it's sized properly... 1st gen trucks didn't have wastegates... most 18 wheelers don't have wastegates... they don't blow up turbos...
besides, you can't get a 16cm wastegated housing for the H1C/HX35 turbine wheel.
Old 09-13-2004 | 05:04 PM
Jambbii's Avatar
Wont the turbo just spin too fast then? Oh, can I use a housing off of a H1C?
Old 09-13-2004 | 05:33 PM
if you're not running too much fuel, it won't spin too fast... if you've still got a 160 pump, I don't think you have to worry about overspinning it...
H1C and HX35 turbine housings interchange.
Forrest
Old 09-13-2004 | 07:07 PM
Jambbii's Avatar
Forrest
Ok , I am getting dvs and 370s very soon, this was just a cheap solution to keep my egts down for a little while. So do you think this may be a problem?
Old 09-13-2004 | 07:29 PM
I think it'll be fine w/ a 160 pump...
Forrest
Old 09-14-2004 | 03:07 AM
Jambbii's Avatar
So what is the going rate for a used 16cm2 housing?
Old 09-14-2004 | 08:07 AM
$100ish? they're $145 new
Old 09-14-2004 | 09:30 AM
BIGHEAD's Avatar
I have my waste gate welded shut & have had for at least a year. I run up to 46 lbs of boost when the notion strikes I still have the stock HX35 so I don't see a reason to have a waste gate my self. That doesn't mean I am not missing something though.
Old 09-14-2004 | 12:59 PM
CTD NUT's Avatar
Oh yeah - at 46 psi the HX35 is WAY overspeeding and out of it's range. That turbo is good for around 35 psi - that's it. The extra psi is coming from the overspeeding turbo superheating the air. This makes egt's go through the roof fast. My HX35 pumps out 46 psi too, but I never bother going that high anymore because it won't make much extra power past about 38 psi. However, IMO the 16 cm housing will be a bandaid fix if you are going to run big dv's and and 370's. You will be able to push alot of fuel with that setup and IMO would benefit from a turbo swap - at least a HX40.
Old 09-14-2004 | 01:41 PM
Jambbii's Avatar
I am going to use it as a bandaid for a littlle while. Turbos are expensive obviously, and I have enough money to do some minor upgrading. A turbo swap is in the future.
ellerman
03-23-2006 01:43 PM
wannadiesel
03-15-2005 08:31 PM
caleb c.
11-25-2004 01:04 PM
boughtadodge
05-31-2004 10:20 PM
dart440_72
07-12-2003 01:23 PM
