Wastegate Adjust on HTT 71 Series?
Hey guys,
Tried to find similar questions and looked around on HTT's website but I could not locate anything. My question is, how do I go about adjusting the wastegate on my HTT 62/71/14? There is a nut tacked to the wastegate rod, but I don't want to do anything and wreck something. Or can I install my boost elbow from my hx35 and throw it on this one?
Reason being, with Smarty on 5 and TST on 6...on a WOT run I will reach about 40-42 psi and 1400 EGT's. I would like to up my boost a little to see if I can get those EGT's down a bit more.
Thanks!
Thanks!
Thanks busa! I'll give that a try tomorrow when I am home. I'm guessing from reading like posts that I want to shorten the Wastegate Rod?
Thanks for the hints guys. I didn't realize the rod was threaded at the wastegate end. I turned it a few turns and noticed a difference, didn't have time to keep turning it and running the truck though.
Thanks Again!
Thanks Again!
Just like JFlory said, there is a nut welded onto the wastegate rod. All you do is turn the nut/rod so that the rod shortens itself.
jmccart
27
02-04-2008 02:26 PM
smkn97s
19
04-16-2007 08:06 PM
COUNTRYBOY
03-31-2007 01:22 PM
