Which waste gate actuator to use
Running a stock 98.5 235 ISB.
The waste gate actuator has a bad diaphragm.
While I'm waiting for the price quote from Cummins, I thought I'd ask you guys about aftermarket actuators.
How do they compare in price to the stock stuff?
Is the Banks Big can a good investment?
Who else makes actuators?
Eventually this engine willl get some mild mods / bombing so it's probably not a bad idea to start with what needs replacing.
Say no to BANK$
Dont bother with the bank$ big head... my brother talked me into putting one on my old truck and it was a wa$te of money... a stock actuator w/ boost elbow is adequate. I have an extra stock actuator if you are in a jam.
Why yes, yes I am in a jam.
I'm stuck in western NY with enough money for fuel to wisconsin and a cummins dealer that wants an arm and a leg and ten days to get me the part.
You can email me at stevie_g@swampfoxcustoms.com or PM me here.
I'd love to work something out with you.
THANKS!!
THANKS!!
Thanks -
Is the engine in a bus or a Ram? Either way if it is bone stock and your not loaded heavy just drive it home. What can it hurt guys run around here with wastegated blocked off or wired shut with bigger injectors and fueling boxes. I wouldn't even think twice about it especially if I had a pyro. If your getting more boost than the ecm wants it will defuel the engine I don't think you would hurt a thing. I sometimes wonder if the wastegate actully opens on a stock truck.
Jed
Jed
I have a stock actuator and manual boost controller and i can get 38# of boost.
sometimes the Banks wastegates need a little tweaking to get them right, but I've had good luck with them , had to adjust a couple of them to get them to hold a little more boost, but afterwards they worked great, dunno how much "better" than a boost elbow they are, but I had good luck with mine, Dusty
I have a banks 14cm wastegated housing and a edge boost elbow. I took the flow through one off when I installed the edge kit. Whould it be benificial to stay with the stock boost elbow? Or would I see to much boost? Right now I can get up to 38 pounds.
How much is the Bank$ big head?
Understand - Like I said, mine came with the truck. I was just wondering if it had some problem I needed to know about ....
I wouldn't buy another one current price is $180 IIRC
Hintonc393
05-04-2012 07:53 AM
tesla440
04-15-2008 06:19 AM
whiteknight
17
01-08-2003 11:38 PM
