Washer GSK??
Washer GSK??
I put the washers in last night and my truck idels at 500 rpm what can i do to fix that? The throttle was sticking and would sit a 2000 till i turned it off and restarted it.
When I did my GSK I had to readjust the locknuts because they were too loose. The truck wouldnt even start at first but I eventualy got it right. Either that or turn up your idle. I didnt have to do that nor have I ever so I cant help with that portion, but you can search it.
Mine did the excact same thing your did tx, I havent had time to fix it becuae I lost third gear that same day and have been working on rebuilding my tranny now. If you find anything out on how to fix this problem please let me know.
Well, like I said, the springs were too loose in the pump so I had to tighten them a little at a time until I got the truck to idle properly. It was time consuming but I got it right and it runs great. You dont need to drive the truck to set the springs, it should idle at about 700-750 in park with the AC on if I remember correctly.
Heres how to adjust the idle; http://www.dodgeram.org/tech/dsl/adj...d_Gen-Idle.htm
I think the setting is different once you change the springs. I used precise calibrated measuring tools and set my 3k springs back exactly as my stock springs came out and it would not start. The stock setting may be a good place to start, but I had to tighten mine down past that point to get it right.
SHARPMACHINE
03-06-2007 08:45 AM
