warm engine miss
warm engine miss
I took out the 200hp injectors and put 100hp injectors in and have had a miss once the engine warms up, when the engine is cold it runs smooth. Injectors have been pop tested and I reinstalled them just to make sure I didn't miss anything. I haven't changed the fuel filter that goes from the tank to the FASS(without filters) but I changed the stock one when I did the injectors. I don't know what the fuel psi is cause the sending unit took a dump, so I have a mechanical one on the way.
Any ideas?
Any ideas?
The Guru
Whose injectors are they? I have had four sets that do the same thing but have also ran injectors that don't do it. It only misses when the motor is running warmish to hot. My jammer and BD sticks both do the idle miss. My formula and DPP sticks don't.
mtb1982
55
01-20-2020 10:45 AM
sam
02-16-2003 06:34 AM
