Want your help in choosing parts for the rebuild
Old 05-13-2008 | 10:01 PM
kas83's Avatar
After reinstalling my head and adjusted my valves, or should I say mis-adjusted the valves, and bending all 12 pushrods, my motor needs to come apart. #3 took the worst hit, and it left some nice gouges in the piston. Head is getting checked out, and will get new valves if necessary. I'm going through the motor top to bottom, I'm not taking chances on this one.
I need 2 pistons for sure. Also need a full set of pushrods. It will get re-ringed and new bearings at the least. Now, do I go with just 2 stock replacement pistons, or go through and replace all 6? Stock replacements, or some type of aftermarket deal? Stock replacement pushrods or upgraded aftermarket? Doubt the rods were in any way damaged, but will have them checked just to make sure. As long as the motor is out and apart, I'm going to send the cam out to be reground. And I will also be installing a Fluid Damper while the motor is out.
Head has been o-ringed, has 60# springs installed, and I will install studs when I put it back together. I'm going to do some porting to it myself, seems like most have had good luck with that.
Plans for the truck are to be a weekend puller, tow a 8-10k lb trailer every now and then, and to be driven to work and on errands on occassion. Basically need it to be able to handle daily driving duties, although my car will for the most part be used, with the truck getting used once in a while.
Planned near future upgrades to the truck will be a set of larger DDP injectors than my Stage 2's, 4K GSK, mild pump work, 64mm turbo, upgraded intercooler, upgraded tranny and dual disc clutch, and other miscelaneous stuff. But the motor needs to come out and is first priority. Will be building the motor to benefit most from these mentioned upgrades.
Sorry for the long post, just want everyone to have a good idea of what I need, what I want to do with the truck, and my plans are. Thanks for any and all help.
nbaggett89
12-26-2015 10:36 AM
I PASS GAS
01-25-2006 08:51 PM
CTD_Neil
07-19-2005 09:13 PM
cLAYH
07-16-2004 04:31 PM
Sudsy
04-18-2003 09:12 PM
