Want list- What order should I get them in?
I have a want list that I can't get all at once. It is possible that there may be a month or two between upgrades. If I buy them one at a time, what order should I get them in? Also some of the items on the list I don't know what exactly to get. Some suggestions would be helpful there.
I know my first thing to get is a transmission upgrade. I am going with either DTT or Goerrend.
The next this is going to be a TST VP44 Pump Cover and TST Powermax3 to replace the Banks Big Hoss box that came on the truck when I bought it.
I am woundering what to next after this.
The truck is used as a daily driver and very rarely is used for towing. I am mainly looking for power and not smoke.
1- Vulcan Draw Straw (I may get this even befor the Transmission)
2- Turbonetics (Spearco) Intercooler (Possibly the BD Cool-It Intercooler if out in time)
3- Upgraded Intercooler Boots
4- ARP Stud Kit
5- High Tech Turbo HTB2 62-12 or 64-12 (Could use some help on this choice)
6- Formula 1 HELIX Two Camshaft
7- Upgraded Valve Spring Kit
8- Formula 1 Mach 3 or 4 (or do I need to go bigger with everythin else I am getting)
9- Water Meth Injection (not sure exactly which one to get here)
10- Fass 150ghp (I already have the 95ghp, with everything above, will I need to upgrade to the 150ghp)
11- Any other suggestions (Probably not going to upgrade to Nitrous, Propane or Twins at this time. These would be way down the road if at all.)
Tell me what you think?
4- ARP Stud Kit
I'd do the FASS first, then start with what Ph4tty said. Should go well with the PM3.
Whoops, noticed you have the 95 already, I think you'd be fine with that.
You are goin about this in totally the wrong way. Make a trip to your local store and pick up some refreshments first. I always do my best thinking with a case of my faves sittin close. After that i would say Fass too.
Women always tell me i only hear what i want and i have vey selective hearing at that. This mite be a case of selective reading. I need to revise my previous post in that i didnt see you already had the 95 FASS. That should be good for around 650hp or more. I would do the turbo. You have got to be runnin awful toasty with what you've got now. I would also do the studs at the same time to try and save your head gasket for as long as possible. You mite want to just consider o-ringin her now and savin the trouble later.
I have yet to see it get to 1000 even on hard throttle.
I had my local mechanic install it. I told them that I wanted it install in the exhaust manifold. Hell its an ATS manifold, pre drilled for the probe.
Now I have to take it back and make them move it.
Frusterating isnt it. You should be able to do it yourself. Just move the plug from your manifold to your elbow and your done. Provided you have the right thermo sensor. From what i saw on some guages they make the post turbo sensors longer.
4- ARP Stud Kit
4- ARP Stud Kit
I think the tranny will need some beefing up if your goin that far and dont have anything done to it yet. If its stock id put that on the very top of the list before you pump out any more power.
If your gonna get the spearco intercooler; you should buy your turbo from turbonetics as well. its a ballbearing unit thats spoolup time is 35% faster then one with full floater bearings and is said to be 50 times stronger in the thrust area
here is a link to it
http://www.torque-master.com/system.php/dodge/
hotrod929
06-10-2008 08:20 AM
jmccart
08-02-2007 12:35 AM
dealseeker
15
12-17-2002 06:43 AM
