Want absouletly the loudest exhaust!
#47
#48
I have an '02 with a 3.5" downpipe, and 4" from there. No muffler or anything, just pipe. I have a 5" tip on it, from what I have been told it that the tips almost act like a megaphone, so go with the 4 or 5 and get 1 inch larger tip than the pipe is (ex: 4" pipe = 5" tip, 5" pipe = 6" tip). The longer the tip the more amplification its going to have to a certain point. I have 6" long tip...
Here is a vid from inside the cab so you can hear from there, almost like in real life, but there is a little more low tone in real life.
Turn up your speakers, helps if you have a sub on them...
http://www.youtube.com/watch?v=KopjN6IBubU
#49
If you just want loud that seems really easy. SAWZALL the exhaust right after the downpipe. I am sure that would be loud, especially whenon the skiny pedal hard.
#50
it is loud, but not nice at all!!!!! driving 20 km like that was more then enough! on the vid of that i posted b4, you cant hear how loud it is...
#51
#54
well on my 02 i have 4" straight pipe and i ran it out under the cab before the rear axle and it is really loud. i think it is the loudest exhaust i have ever heard. look at my pictures and you will see where i have it. i made it myself also.
#55
I say go 5". It'll sound GOOD!
#57
Wow, lotsa replies!
I like the thought of a 5" system, but I dont like the thought of the power loss due to scavenging, especially with the pipe expanding to 5" right out of the turbo. Probably wouldnt lose much, but I want all i can get
What would be perfect is stock downpipe, expanding to 4" to the front of rear axle, and then expanding to 5" tailpipe dumping in the same location, but who sells something like that? would probably have to be custom. that way, it should minimize scavenging and still get closer to that 5" semi sound all of us love
any ideas
any ideas
#58
Hmm...now I'm not claiming to be an expert but as far as outside the cab noise goes, i've noticed that stacks don't seem to be as loud as a regular exit exhaust. Also, the common rail is definately a quieter engine but the exhaust is definately louder than a 24v. It is more raspy and sounds worse IMO but is definately louder than a similar 24v. Dual setups seem to dampen the loudness also. Personally the louder (definately more obnoxious) 24v i've heard is my buddy's 01 with stock straight piped and a "custom" 6" tip. Before i made up my downpipe i had a turndown off of the turbo and that's it! It's definately loud but will make any drive miserable. A good straight 4" would be the ideal compromise between sound and exhaust flow, oh and with a 5 or 6" tip. It's not that 4 or 5" isn't loud, it is just loud with a different tone. Just my .02
