Walbro with Vulcan relocation kit???'s
I have the Vulcan relocation kit and the stock LP is crapped out and im about to buy a drag comp. I need more FP than the stock pump can produce.
I would like to try to Walbro because the volume it can produce. How would it plump into the vulvan kit etc.....
Has anyone done this, are have suggestions on another pump I could use:
Holey Blue, etc......
TIA
Jamie
Pretty much tell me what to do.
PS: FASS is too much right now.
TIA
Jamie
TIA
Jamie
TIA
Jamie
do the holley blue, its plenty and cheap. im getting 21-24psi@ idle,18-19 cruising, all by its self. my factory lp just crapped out over the weekend. i should be getting close to 26psi@ idle when i get my new lp tommorow. that holley blue saved my VP44. just call erik at Vulcan, tell him what your going to be doing, he will tell you what you need, if anything. super nice and informative guy.360 713 1549 is his ph#
hope this helps, dieselfan
I thought the holley blue would only put out 14 psi max by its self?? If not then ill put one in this weekend. I have the vulcan kit that just allows for one pump at the tank.
thanks,
Jamie
thanks,
Jamie
sdsaw
02-10-2007 09:36 PM
berettaman
07-19-2006 10:02 AM
AltavistaLawn
12-28-2005 09:06 AM
