Walbro lift pump for VP-44?
Old 01-04-2006 | 05:24 PM
roadranger's Avatar
I've been reading all the threads about the Walbro lift pump replacement for the 3rd Gen trucks with the CP-3 injection pump.
Would the Walbro lift pump work on a VP-44 truck?
Too much pressure? Can you bypass it somehow?
The Walbro seems like a better running alternative than most aftermarket pumps, and at less than half the price of a Fass, which is subject to brush and bypass spring failure...
Anyone running a Walbro on a VP-44??
Old 01-04-2006 | 05:39 PM
Superduty's Avatar
See my post in General Diesel.
I put it there so that everyone, stock or modded would see it.
Enjoy !
Old 01-05-2006 | 03:12 PM
roadranger's Avatar
Superduty, I've read your post there.
However, it doesn't say if the Walbro, which puts out 60 psi, will work on the VP-44 injection pump which needs to see ~15 psi maximum.
So, how would the Walbro be set up to run a VP-44 equiped Cummins?
Old 01-05-2006 | 03:21 PM
srt20's Avatar
yes i would like to know this also, it seems like a good alternative so far.
Old 01-06-2006 | 03:53 PM
roadranger's Avatar
to the top
Old 01-06-2006 | 04:07 PM
Superduty's Avatar
VP44 application needs a regulator if I understand correctly.
I think I would plumb it like the CP3, ie with a bypass and put the regulator in the bypass line. Set the regulator to the pressure you want and it will stay there, idle or WOT.
Here is the original post. https://www.dieseltruckresource.com/...ad.php?t=78702
streetsmoker
26
11-04-2019 11:27 PM
D.S.
03-01-2007 11:15 PM
Jordan5687
03-01-2007 01:06 AM
Jordan5687
02-28-2007 01:15 AM
the_fox_man4
13
12-26-2006 03:10 PM
Quick Reply: Walbro lift pump for VP-44?
