Walbro GSL-392 inline pump
Is a Walbro GSL-392 inline pump a good pump to put inline cuz im just goin to make a 3/8 fuel line kit myself . does anyone know what all fitting ill need cuz i think its cheaper ?
The Walbro Pump should com with the two barb fittings off the pump. You will need a pressure regulator, a tee for the regulator to go into, 12mm adapter to the back of the Fuel Filter housing, and the other fitting depends on what size AN fittings you want to go with 8 or 6. You will also need a relay harness. These Walbro pumps pull to many Amps to pull power from the Factory connection. You will also need mountings hardware for the Pump. You will have to come up with something to put the return to the tank also.
that is the walbro kit i think or its vulcan's big line kit.
call erik at vulcan 360 713 1549 or www.vulcanperformance.com , tell him what you what to do and he will hook you up, super nice guy.
check out www.glacierdieselpower.com
dieselfan
It is the AFS Big Dog Fuel system. You can find them atwww.wideopendiesel.com or www.altfuelsolutions.com Just installed one a friends truck tonight.
Jordan5687
02-28-2007 12:15 AM
streetsmoker
24
05-07-2006 12:26 AM
