Walbro 392 kit
Walbro 392 kit
Ok, so i was looking at the 392 kit from glacier. The kit was $419. Now, it said also recommended was the "big line kit". It came with larger fuel line to go from my filter housing to my VP. Is this kit worth it at an extra $69? It also comes with a fuel pressure sender T for a gauge. Will my edge juice with att fuel pressure sensor screw right into that T with no problems?
Also, what kind of PSI are you guys getting with these systems? I have narrowed my choices down to the walbro, and the fass HPFP. Any ideas are welcome.
Also, which of these systems is easier to install, and replace a part if one fails?
Walbro
I have the 392. Its a good kit and the Rich is an awsome guy. I dont have the big line kit and I run 21 idle and no lower then 13 wot. Yea he told me the fp sender will screw right into the t.
I have the 392 also but don't have the big line kit... yet.
Nice system. Easy to install instructions are great.
I run at 15 psi idle maybe drop to 14 at wot. The kit has a regulator so you can adjust the psi you want.
Sixpack73
14
10-14-2007 11:04 AM
streetsmoker
24
05-07-2006 12:26 AM
