walbro 392 in
Old 08-15-2006 | 04:53 PM
dieselrob's Avatar
walbro 392 in
Well i got back on the road this weekend. I have a 3/8 bypass line with a valvein it to regulate the pressure. I am idleing at 19-20 psi, but if i get on it full trottle with the comp on 1-5 it pulls down to 5 psi. Cruiseon flat is about 14 15, Up medium hills about 12, 9%grade at 60 its hold 10. I just dont like the full throttle runs pullin it down to 5. I didnt even turn the comp up at all. 5x5 might suck it dry. And i also dont wanna idle any higher. Any suggestion to help my full throttle psi, Id like to go pull on sept 2, and mabey hit the strip befor then.
Old 08-15-2006 | 05:40 PM
HOHN's Avatar
You need proper bypass fuel pressure regulation.
A bypass regulator like those sold by Aeromotive will maintain steady FP and solve your problem.
Justin
Old 08-15-2006 | 06:57 PM
piperca's Avatar
Mallory 4307M is set to deliver 4-25psi and you should be able to find it online for around $80.
Old 08-16-2006 | 02:53 PM
dieselrob's Avatar
Yea i have come to that conclusion today. I really noticed i was losing topend umphh. Another thing is my pressure was surging today it was bumping up to 26 at idle sometimes. Is there any other recomended regulators. Any one know how much the one from glaicer diesel costs? Or how bout the regulator you use with holley blues can that be used? I have some of them layin around.
Old 08-16-2006 | 03:13 PM
dieselrob's Avatar
Well i was lookin at the mallory and aeromotive bypass regulators, but whats the deal with the boost port on them? If were to get one and hook it up what do i do with the boost port.?
Old 08-16-2006 | 05:52 PM
DMcPherson's Avatar
I have been thinking about that exact question, and am thinking of using a boost reference regulator my self. set it low and use the boost reference. it should multiply pressure. so more under load and less at idle.
Im very curious to know if anyone has done this so far
Old 08-16-2006 | 05:59 PM
HOHN's Avatar
Um....uhhh...you connect the boost port to a source of boost pressure
Configured this way, your regulator will add 1:1 to the baseline fuel pressure as boost comes up.
For example, say you set it for 15psi baseline.
You'd have 35psi FP at 20psi boost, and 55psi FP(!) at 40psi boost.
Personally, I'd plug the boost port and just give the VP a constant 18-22 psi or so.
jmo
Old 08-17-2006 | 04:08 PM
dieselrob's Avatar
Ok thanks, i wasnt shure if you could just block the boost port off or not. I have a mallory on its way.
Dodge Demon
08-09-2006 07:58 PM
d0dg301
08-07-2006 12:13 AM
Austin'sDodge
22
07-30-2006 10:31 PM
streetsmoker
24
05-07-2006 01:26 AM
Dodge Demon
02-27-2006 07:47 PM
