Wake up bottom end 12V
Old 06-23-2005, 08:37 PM
doodah's Avatar
Goerend tripple disc- $1200 That what I went with! and some billit goodies!"""HOLD ON!!!!!"""
Old 06-24-2005, 03:24 AM
killfast1's Avatar
That kind of blows his $1K in just one wad, actually exceeds it.
Old 06-24-2005, 08:45 AM
Txwelder's Avatar
Being on a budget and wanting to buy upgrades is hard. Maybe I will just stash the 1K until I can save more to do everything at one time. Probably my best bet instead of buying one piece of the puzzle at a time.
Old 06-24-2005, 12:47 PM
Txwelder's Avatar
So I shopped around for TC's and found them to be pricy but probably good product for the price. I did see some converters advertised on ebay but not with any brand names I recognize from this site so they probably arent tested proven by REAL Cummins owners. Does Goerends have a website?
Old 06-24-2005, 04:45 PM
Rrloren's Avatar
Try Goerendsbros.com
Old 06-24-2005, 04:55 PM
cumminsdriver635's Avatar
www.gbtransmissions.com
Eric
Old 06-25-2005, 01:42 AM
Txwelder's Avatar
So my wife decides she is going to give me 2K instead of 1K so that makes things a little easier. Deffinately a good TC, VB, 3Kgsk, 370 injectors and some DV's but what size? 181 or 191? Still running stock turbo so what can I get away with?
Old 06-25-2005, 02:13 PM
bmoeller's Avatar
180 and 215 pumps already have the 181 DV. I have a set of 191DV waiting to go in (need a socket), so I can't saw what increase there will be. If the pump is otherwise setup properly, the 181 DV will flow enough fuel for 800hp.
The stock turbo won't take the #100 and the 370s together. WAY too much heat. I'm hitting 37#/1300* (preturbo) with my setup. Don't know if a 16cm2 housing will be enough on an otherwise stock turbo.
Old 06-26-2005, 03:07 PM
Txwelder's Avatar
Anyone else have any input on which turbo to run with 370's and a #100 plate?
Old 06-26-2005, 04:23 PM
gwhammy's Avatar
A stock hx40 with a 16 housing ain't enough. I can hit 1600+ in first gear.
Old 06-26-2005, 05:28 PM
Txwelder's Avatar
So who has the right setup for the 370's and #100 plate? Anyone running them efficiently and not making rediculous heat?
Old 06-26-2005, 06:09 PM
bmoeller's Avatar
If my engine had the timing advanced, the EGTs would be cooler. It works quite well.
I think a HTB2 would be even better. Better spool up off the line. I can spool the 40 pretty well. Once the fuel comes on, it lights pretty dang quick. If the plate is slid back though, it isn't as easy to light.
Have the plate full forward now. Really takes off now.
Old 06-26-2005, 10:22 PM
Crimedog's Avatar
Give Dave a call about the transmission first. He'll be honest with you and help you get set up right the FIRST time. I would definitely go with the triple disk, and ask Dave about a valve body. Then I would get the 3k GSK, that's the best bang for the buck. Then I would save up and get the 370s and hybridize your turbo with HT Turbo. This is the plan I am trying to head down, but I'm also on a budget (gonna start 1st year of college next fall). I'm trying to build it the smart way, because I won't be able to afford any unexpected breakdowns! If you do the injectors and DVs first, you'll be buying a torque converter right away anyway because it's gonna slip big time! But, that's just my 2 cents...
Mule Skinner
07-07-2003 12:18 PM
bigfoot
03-29-2003 09:52 PM
shortround
12-26-2002 10:53 AM
Scotty
12-20-2002 12:06 AM
Quick Reply: Wake up bottom end 12V
