wacky
Old 05-13-2004 | 05:53 PM
Floorman's Avatar
wacky
hi guys ,i had a new lift pump put in my truck oh 5000 miles ago and i have been noticing that the fuel pressure guage is starting to jump around alot. be running down the road at 10 psi and then look over and see 5psi but if i gas it she jumps right to 10 idle is fine stays at 13 to 14. could this mean i need a new fuel filter? i used a napa one last time maybe 5000 miles on it.
thanks
Old 05-13-2004 | 06:18 PM
BigBlue's Avatar
Sounds like the check valve on the lift pump is doing funny things. Try replacing the filter and see what happens.
Old 05-13-2004 | 06:33 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Also check the wire conections to be sure they're clean and tight.
Old 05-13-2004 | 07:43 PM
Floorman's Avatar
ok i will try these things thanks
Old 05-14-2004 | 07:18 AM
bluebull's Avatar
I had this happen to me after changing out a new lift pump. It turned out to be the relay in the power distribution center. The one under the hood on the drivers side. Just switch it out with another one, like the horn relay for example.
Old 05-14-2004 | 01:18 PM
Floorman's Avatar
thanks blue bull i will try that
rjrkihap
07-07-2005 03:49 PM
Strjock81
01-24-2005 07:54 PM
hotdram
01-09-2005 04:00 PM
dieselminded
10-15-2004 07:44 PM
Dieseldude4x4
09-02-2004 10:29 AM
Quick Reply: wacky
