Vp44 Pump Cover Question
Old 05-03-2005 | 08:05 PM
CTD2001's Avatar
I ordered an Edge Comp along with a BD pump Cover to make a better connection, (everyone seemed to recomend this) anyways, i was reading some installation instruction for the new pump cover and aparently the old cover has what they call on the 2001-2002 models a "#25 TORX PLUS TAMPERPROOF" screw. Is there a special tool that i need to remove these, I know that BlueChip Diesel Performance sells special toos and if i need one, i want pick one up. Or can these be removed with another tool, Thanks for the Help
Old 05-03-2005 | 08:12 PM
Buckshotmckee's Avatar
The kit should come with the tool, mine did.
Old 05-03-2005 | 11:34 PM
MLR1's Avatar
Some pumps have tamper proof screws and some don't. My pump didn't have the tamper proof torx. If the screws have a pin in the center of the torx tip provision, they are tamper proof and you will need the special bit. If the screws look like a normal torx, you can just use a normal torx and you will be good to go.
Old 05-04-2005 | 12:09 AM
torquefan's Avatar
I was looking at some of the screws in a VP44 awhile ago, and they look like a tamperproof torx, but they aren't. Only 5 points instead of 6. Couldn't get anything to match it.
Old 05-04-2005 | 12:22 AM
MLR1's Avatar
Very interesting. I never looked at the number of points. I did notice that the bit that Blue Chip sent me the tips on the torx are flattened instead of pointed and has 6 sides.
Old 05-04-2005 | 11:41 AM
Olratlr's Avatar
Pump cover Question
Blue Chip sells the Tamper proof Torx Bit.
Old 05-04-2005 | 12:21 PM
67HotRod's Avatar
Tamper proof, then don't know us very well. Do they....
clinton81
02-24-2007 01:56 AM
Dusty Ratcliff
05-23-2006 11:05 PM
suzukiZrider
01-13-2005 09:20 PM
Commatoze
0
10-15-2003 01:33 PM
BluDiamond
17
01-28-2003 08:01 PM
