VP44 pump
VP44 pump
At what point in your bombing project would you exceed the capacity of the VP44 or is there such a thing, I looked in the Tech facts section and did not see anything pertaining to this. Thanks for any input.
Re:VP44 pump
Exceeding Capacity on the VP44.
If you are asking at which point is the VP44 is "petered out" ?
I think a stock VP44 is capable of supporting a 550hp truck of course this is with large injectors, the air to burn the fuel, and a pusher setup and fueling box.
There are some trucks producing more hp on Diesel with a VP44, but not many. Some Trucks that produce more have a "tweaked" pump, and others producing more hp with a VP44 are using Propane or NOS or both.
There are some exceptions no doubt (further confusion!!).
--Justin
--Justin
Re:VP44 pump
[quote author=PourinDiesel link=board=7;threadid=8129;start=0#78431 date=1039539364]<br>Exceeding Capacity on the VP44.<br>If you are asking at which point is the VP44 is "petered out" ?<br><br>I think a stock VP44 is capable of supporting a 550hp truck of course this is with large injectors, the air to burn the fuel, and a pusher setup and fueling box.<br>There are some trucks producing more hp on Diesel with a VP44, but not many. Some Trucks that produce more have a "tweaked" pump, and others producing more hp with a VP44 are using Propane or NOS or both.<br>There are some exceptions no doubt (further confusion!!).<br><br>--Justin<br><br><br>[/quote]Thanks Justin, that awnsers my question, I think...How do you like that Edge Drag Comp
Erska
17
03-06-2009 09:52 PM
