VP44 Fuel pressure
VP44 Fuel pressure
Ok, I would like some solid answers on this issue , How much pressure will the vp44 handle before you have problems? Just trying to get a good reliable supply system without breaking the bank.
You will get lots of differing opinions on this issue
I,m still running my original VP44 I have been running 25psi at idle It never drops below 18psi at WOT I've been running this setup for over 2years no problems yet.
all stock except the pro-comp(or holley blue,pro-comp uses the old holley blue design before holley revamped theirs) pusher pump, had to adjust spring pressure in pusher to get psi where i wanted it, works great now.
Erska
17
03-06-2009 09:52 PM
