vp44 change to 7100
vp44 change to 7100
I'm sure I saw somewhere, a conversion from the 24V inj.pump to the 12V injection pump. Can anyone help me out?
The reason I'm interested, is to get rid of the VP44, and the APPS problems.
HEY I found a site that uses this set up. www.cumminsracing.com or type cummins dragster in yahoo. The thing is badddd.
Schied Diesel and Piers Diesel Research make kits to convert the VP44 to a P7100. At minimum you'll need a boat load of cash (> $5k). There's a lot more information if you search this forum for VP44 swap or P-pump 24valve.
brandon.
brandon.
Search "p7100 conversion" in this forum. Look at the thread by trath(something like ) He did a conversion without spending a bundle. Last I read it was doing fine. Make sure you start off with a pump that has just been put on a test stand. Trying to figure things out with a bad pump can cost you double, and give you chest pains.
I would contact J.R Adkins. 3172813130. I have seen him do a few sets and man to they run good. He would know all the parts you would need and he might even have some of them at his shop.
DM01
DM01
Diesel-Dan
03-05-2005 10:00 PM
