the vp lope
Old 02-04-2009, 02:45 PM
2141pete's Avatar
Mine loped with just an HRVP. I plan on throwing in a set of .093" tubes and I'll see if it does it again.
Old 02-04-2009, 03:43 PM
Brokenarrow's Avatar
That was with the scheid lighting on it right before i took it off! But it still has the same lope with the new dragon flow extreme! HA Yeah sitting at a light is kind of funny at sometimes, lot of *** looks! Get the diesel arent supposed to lope alot to! No the silver bullet is not to hard to spool with my setup!
Old 02-04-2009, 07:13 PM
smoketracks's Avatar
Sounds great. Like the stacks with straight exhaust. I might just have to buy larger lines just for that lope!!
Old 02-04-2009, 10:46 PM
Red3quarter's Avatar
Brokenarrow, truck sounds good! I like how a cummins sounds when it lopes like that!
Old 02-05-2009, 10:05 PM
dieselcamp's Avatar
Reminds me of the Detroit 2 stroke jokes with th buffer screw out. On those missadjusted buffer screws caused the govenor to hunt at idle but dissapeard off idle.
It does sound cool.
Just reminded me of someting else, when I was a kid the older kids that had cars would try and achieve a lope by adjusting the carb and timing just for that sound, couldn't afford high lift cams yet.
Old 02-05-2009, 10:08 PM
dieselcamp's Avatar
Originally Posted by Brokenarrow
The lope does not raise the rpm gauge at all! I can post a video of mine loping with the idle staying right at 700 and not moving!
Looking at your set up there, what is the highest rpm you can get?
Old 02-05-2009, 10:13 PM
now 3700 but soon 4K+
Old 02-05-2009, 10:31 PM
dieselcamp's Avatar
Love It!
Old 02-07-2009, 12:52 PM
Big Deezul's Avatar
I had similar lope on my 24v like that video and the only way I could get it to go away was with dd4 or bigger injectors.
I know it sounds cool at first, but its annoying to drive and to cool down when you are trying to be half way quiet
Old 02-07-2009, 07:18 PM
stuckey200224's Avatar
it lopes because the injectors just barley have enough pressure at idle to open causing the lope you can put the biggest cam ever made in a diesel and it wont lope. there is no fuel going into the cylinder from the head so a cam will not make it lope.
Old 02-07-2009, 07:24 PM
Originally Posted by turbo246
i always thought a true lope, like on the top fuel dragsters was becasue of the cam. delivers all the fuel it can at high rpm and causing it not to run smooth untill it hits the fueling band notice how the smoke goes from white to black on them pullers
the smoke on a puller goes from white to black because they dont get full fuel till the chargers lite and on the line when they turn the water on it will put some of the fire out till the eng gets hot enough to vaporize it.
Old 02-08-2009, 02:11 PM
Number47's Avatar
white smoke is also a diagnostic indicator of poor timing (assuming its not cold outside and engine is at temp)
Old 02-11-2009, 04:18 PM
chali84's Avatar
curios why did you switch to the dragon flow over the schied?
and could an automatic run .093 lines and tubes with the schied or dragon flow pump with out the worry of stalling when put in gear
Old 02-11-2009, 06:00 PM
The dragon flow is supposed to fuel %140 more then the scheid or any other hotrod pump! As for your ? about the auto you will have to call II mine is a manual!
Old 02-11-2009, 07:32 PM
MDowns's Avatar
i was wanting to know if you can put the .093 lines on a truck with the stock ho pump with .093 tubes and big injectors?
Satan's Chariot
07-11-2006 02:50 PM
nagel
07-04-2006 10:29 PM
SoTexRattler
03-14-2005 10:28 AM
crossy
14
10-15-2004 09:58 PM
dodgeman01
13
04-08-2003 12:50 PM
Quick Reply: the vp lope
