vp 44 question
vp 44 question
After much deliberation i am going to hook up my fuel gauge to the test port on my vp 44. Problem is i can’t seem to find it. So could you all point me in the right direction as to where exactly it is on the pump.
look on the injection pump where the fuel line goes in the pump. there should be a red or black cap on the banjo bolt that you have to take off before you screw on the gauge.
Thanks for the info. I figured that's where it was but wasn’t quit sure. When i removed the cap and started the truck, fuel did not flow out so is there a special fitting I need to buy?
You can use the schrader valve that the factory used to use for testing or install different banjos that has a port to connect your fuel pressure gauge to. If you go this route, alot of folks install the banjo on the filtered side of the fuel filter (on your, this is the bottom banjo).
If you are installing a new banjo, might as well install some monster size banjos to help the fuel pressure!!!
HTHs,
Joe
HTHs,
Joe
Thanks for all your help. Just finished installing the gauge and thankfully I won’t be needing to replace the lift pump. 9 pounds pressure when pulling a somewhat heavy load down the highway.
Registered
thats borderline. keep a eye on your psi!
mkeanglorldo56
11-04-2007 12:34 PM
Oval Racer
01-26-2007 02:57 PM
8mpg
05-08-2006 06:37 PM
