Vp 44 code tester?
Old 02-03-2007 | 01:18 PM
stroker4501's Avatar
Vp 44 code tester?
I just had a quick question. Is there a special tool to read the codes on our VP44's or do you just do it with a normal code reader that plugs in under the dash? thanks in advance mario
Old 02-03-2007 | 01:25 PM
smokindog's Avatar
Any OBDII unit will read the codes for you. Nothing special required for the VP44.
Old 02-03-2007 | 01:36 PM
Ok thanks i went to autozone to see if i have any codes because i have been getting bad fuel mileage about 12mpg. I have no check engine light, but i thought i would check.came out clear. If the vp44 does have a code will the check engine light come on? aslo i just replaced a lift pump.thanks mario
Old 02-03-2007 | 01:50 PM
cejrunner's Avatar
Stroker, my VP actually quit and it did set a code of 1688 and PO252. Which both point to the electronics attached to the pump. I had no warning before if quit on the interstate a long way from home. I have heard of others going to a limp mode and bearly running but not sure if that sets a code or not.
Old 02-03-2007 | 02:06 PM
smokindog's Avatar
The check engine light will not always come on when your truck sets a code. Look here for a description on some of the more common OBDII codes. AutoZone should have a scan tool that will be able to read your codes for you.
Poor fuel economy could be a few things. Get the codes scanned and let us know what, if any you find.
Old 02-03-2007 | 02:42 PM
I did have them run the code tester and it came out clear. what else should i do about the fuel economy? mario
fitzer
02-17-2004 06:53 PM
GatorRam
10-10-2003 04:35 PM
97CTD
04-04-2003 05:14 PM
nascar mark
01-21-2003 03:44 PM
nascar mark
01-19-2003 07:22 PM
