Video on fuel plate and GSK install??
tst has a video for the plate they might just sell you the video if you call them. if not i know a member on here who has one, because i just sold hin the whole kit with video. where are you from maybe someone would just come help you
didn't your parts come with instructions and a video,i know TST comes with them.here are some links incase you need them.
http://www.tstproducts.com/index.asp...on=Custom&ID=4
http://www.piersdiesel.com/Technical.htm
I just got a kit off Ebay, it doesn't come with a video. I'm sure I can do it without a video but I would like to see one since it may make it a little easier. I'll contact Pittom. If he doesn't want to loan it, is there anyone else out there that would. I'd be glad to reimburse for shipping.
The video is optional from TST. It is purchased seperately from the kit. ~$10 or so, IIRC.
BG, is the plate a "real" plate, or a ground stocker? Did it come with installation instructions? If not, they are HERE The pics are all you really need to do it. The instructions are easy to follow.
Personally, the video is a waste of money. It is pretty self-explanatory, once you get in to it. Plus, with the pics I posted below, you won't really gain much with the video. It isn't of very good quality.
More pics-
Top of AFC housing, installed
Alignment plate installed
Plate installed
Boost fitting installed
****NOTE- On some trucks, the fitting replaces one that in on compressor housing on the turbo itself. Not on the AFC housing.
Bottom veiw of AFC housing
If you really must have the video, I still have it. Send me a PM if you want it.
More pics-
Plate installed
The auction just ended today on EBAY. This ebay person was mentioned in another thread and it seemed like a good deal (machineshopcharlie). The add said,
"This kit comes with a torque plate , set up plate , a 6mm bolt to replace the break off screw if necessary , and a boost fitting" and instructions. The starting bid, which was the winning bid was $119 including shipping for a #6 plate. I hope it was a good deal.
bmoeller, I just noticed you have a trans from Goerend. Dave helped me out alot a couple years ago when I built up mine with extra power in mind in the future. I couldn't believe how helpful he was. I'm still at stock power but finally decided to boost it up a bit. Dave is great!!!
mybajadodgeram
03-30-2012 10:41 AM
esgdakota
13
01-17-2012 05:28 PM
Dave88LX
02-12-2006 11:29 PM
DRM
01-14-2004 07:47 PM
