variable geometry HX40V compr map up for grabs
Found a HX40V charger compressor map, used in a 7,8 liter IVECO engine. It even has a comparison curves between wastegated and variable geometry chargers. Neat.
Please do not fail to click the 'view full size' text at the bottom of linked page.
http://community.webshots.com/myphot...ecurity=zGyKvq
I just wish a compressor map meant something to me
Presure vs air flow makes sense, but the circles around them?
I aced calculus, but am still clueless. Sombody pm me and beat some sense into me piz
Thanks for posting artsi- nice find
The airflow axis has a cubic meter format, rather than lbs/min as what Holset usually uses.
I visited following web page to find attached formula to do conversion to lbs/min flow. (Note, formula has flow per second, and compressor map has flow per an hour !!!)
http://www.ztechz.net/id6.html
1 m³/s = 2118.88 cfm, 10 lb/min = 144.718 cfm
Circles are "efficiency islands" and show the efficiency: 60%, 70%, 80% etc.
The other radii are shaft speed in RPMs (80,000; 90K, 100K, etc)
A compressor maps relates shaft speed to 1) pressure ratio 2) airflow, properly listed in POUNDS of air (mass), and 3) efficiency
jh
this will pretty much fill every last bit of brain space you have left with turbo information.
http://www.turbomustangs.com/turbotech/main.htm
hope ya got a couple minutes.
This site ain't too bad either:
http://www.gnttype.org/techarea/turbo/turbopage.html
PeterT
77
09-18-2006 08:16 PM
Artsi_L
02-05-2006 11:47 PM
PeterT
03-02-2005 09:29 AM
