vanaaken D500
vanaaken D500
I recently got an used vanaaken box from a guy that bought a new dodge w/ 600 ft. pds and didnt this box so i put it on my 2002 h.o. six sd. it was a very big improvement . that was about 5 months ago and today i started loosing power and blue smoke and i took it off and every thing seems ok it just seems like i dont have any power with out it and i have 207,000 on the truck now and i do a lot of pulling truck and trailer wt. is 17,300 empty wt. has any one else had trouble w/ the v.a. box?
Hello hauliday
Welcome to the site. It would be a good idea to fill in the signature area of your profile with the stats of your truck.
I looked up your problem in the Dodge service manual and at the top of the list was dirty filter and an air leak between the turbocharger and intake manifold. There are sever boots that can come loose. I would check all the boots from the turbo to the intake and make sure they are tight (real tight). Also check for any ruptures. I won’t go into the air filter you know what to do there.
Hope this helps.
Hope this helps.
sawboywv1
06-14-2004 03:29 PM
