van aaken vs edge
van aaken vs edge
I have the VanAaken box in my truck right now, really happy with it but i want more power..... so i've been looking into things here.
i straight piped my diesel, and i put a k&n in it.
i'm gonna do the injectors soon and maybe the turbo here in the late future.
now down to the point.. the va box puts out 75hp roughly where as the edge comp puts out 120 at maximum....... now is there something there not telling me... any cons to the edge at max power..... and i don't care about smoke, i actually kinda like it
but comments suggestions??
also my old truck has 270k on her now if that affects anything.
Thanks
Sean
Thanks
Sean
VA Box is comparable to Edge EZ Box. Edge Comp Box taps the Injector Pump wire. It's the only way to get more fuel...as opposed to redistributing when the fuel comes in (VA Box & EZ).
Most here love their Comp Boxes. You could stack your VA on to a TST PM3 Box and I believe you will see stronger top end. Some will argue this point. Before you do either....get gauges!
You don't list tranny in signature but whichever you have, you will need to spend some money there to get most out of Comp or TST Box.
Both tap the IP wire and get more HP.
RJ
RJ
RJ
RJ
so your saying to put the pm3 inline with the va box?!?!?!
after looking at the tst products i really like that remote selector with all the guages built into it... i could see myself getting that.
edit: oh i'm an auto. nothing done to it yet... but the tranny is ready to drop out at any min and i'll put in a full performance one.
Yup, Stack them. VA gives you timing and low end fueling...PM3 gives you heavy fueling when the boost kicks in.
-PM3 plugs into block MAP sensor
-VA plugs into PM3 (and Data Port)
-Stock MAP Sensor plug goes into VA reciever.
The EDGE Comp gives you both in one box (but no gauges) so it's your choice. Can't go wrong either way. I personally prefer the TST PM3 HP Dyno Curves to the Edge Comp...but booth boxes are excellent.
RJ
RJ
Originally Posted by blackdiesel02
go with the drag comp. its supposed to be like 160 or 170?
Originally Posted by IntakeRacing
huh thanks! will i need any supporting mods other than tranny?
-4" exhaust, could wait for injectors
-Bigger Air Intake Now - Scotty II from DTR Co. Store
-bigger turbo
Keeping the TST Box on 1 or2 (out of 9 settings), you could be ok to drive till you get the above.
Good luck
RJ
To balance the package, for full power, you will need...
-bigger turbo
Good luck
RJ
-bigger turbo
Good luck
RJ
as for the 4" exhaust i have a 3" thats straight piped all the way through, that won't be enough?
Stock exhaust is fine with any box until you start adding injectors to them. A TST box or Edge box doesn't NEED a 4" per se, but you will notice a benefit from it as far as EGT reduction and turbo spoolup. So it may be a "nice to have" or it might be a "must have" depending on your driving style, EGT comfort range, and budget.
Now, you slap in some 100hp+ injectors on top of your aggressive fueling box and a 4" becomes closer to mandatory. Most people consider the stock exhaust good to about 375hp or so.
A fueling box alone will put you close to 320 (depending on how strong your truck is to begin with). Adding injectors can easily take you over 350.
With my injectors, a fueling box would give me about 475hp worth of fuel. Too bad I only have about 350hp worth of air
wow am i learning a lot in this thread......
now everybody is talking about fuel upgrades.... are they just talking injectors.. or should i do more?
~Nick
Hopefull he is not planning on waiting till the power-core is needing replacement.
How is that working out for you? I read everypost with your name about airfilters.
