Van Aaken or Power Puck
Would running either one of these boxes with only an AFE stage 2 intake and everything else stock without a boost fouler cause the boost to go over 20psi and trigger codes?
Without a wastegate boost elbow installed, the wastegate should do it's job and vent things off and keep things at stock boost levels.
Add some larger injectors and it would be another story.
Why not use the boost elbow? Your max power gain and best EGT reduction is going to be above the stock 20# boost level, probably closer to 32-34#. If you don't want to go with a fixed boost elbow, get an adjustable unit to set it where you want it.
Originally posted by tool
The Van Aaken has a built in fooler like the EZ doesn't it??
Where would I get a boost fouler for around $50. Also I decided on the power puck because I was told it has the boost fouler built in. Can anyone verify this for me? I sent an email to Diablo asking them but I haven't received anything back from them.
http://www.usdieselparts.com/category.cfm?Category=905 this otta help. I am very happy with the Van Aaken, Irun the c5 and it is great
05doolie
04-12-2009 05:15 AM
BIGDAN65
16
01-23-2008 10:02 PM
MARKY MARK
02-08-2007 07:52 PM
