Valve springs....
Old 09-21-2007 | 06:04 PM
I SPEED's Avatar
Valve springs....
Easy to do with the head still on? Or should it be pulled off to install them?
Old 09-21-2007 | 06:19 PM
HOHN's Avatar
This is something I'd like to know as well.
I'm hoping to stud my head and upgrade the springs without taking the head off...
Is it possible?
Old 09-21-2007 | 06:33 PM
pmtg's Avatar
i thought it was possible, as long as you remember which piston is at TDC... http://www.cumminsracing.com/images/...ting%20005.jpg. looks like the valves can sit on the crown in the TDC position.
just my observations, but i'll let someone who's done this chime in...
Old 09-21-2007 | 08:25 PM
pmtg's Avatar
go to post #26:
https://www.dieseltruckresource.com/...ht=valve+float
Old 09-21-2007 | 10:26 PM
HOHN's Avatar
MMkay-- next question:
How can I know when different cylinders are at TDC? Just crank the engine with the valve cover off and wait until it LOOKs like the valves are closed?
There has to be a better way. Is TDC #1 marked on damper? I dunno if there are any timing marks at all on the damper (I thought they were all on the gears inside) and I don't want to pull the gear cover just to do this.
Justin
Old 09-21-2007 | 10:49 PM
pmtg's Avatar
heres what they say about finding TDC for valve lash... https://www.dieseltruckresource.com/...n&onlynewfaq=1
Old 09-21-2007 | 11:06 PM
HOHN's Avatar
Cool! Thanks. I'm not sure how ambitious I am with tackling a lot of this stuff.
The barring tool would be useful for lot of things. I can imagine turning over a 5.9 by hand can be pretty tough-- that's a lot of compression!
Old 09-22-2007 | 12:07 AM
pmtg's Avatar
youre welcome!
yeah, ive tried the alternator option and it was worthless...the serpentine belt just slipped! big surprise!!
i think the barring tool might be worth the money...
Old 09-22-2007 | 12:17 AM
1-5-3-6-2-4's Avatar
I just set my valves last night. you can easily turn the engine over with a 22mm socket with 1/2" ratchet on the alternator nut. it will ONLY turn the engine over backwards though.
and the running mate pistons 1/6 2/5 3/4 like was said before you can do the valve springs on each pair when they;re at TDC. for the old 24valver start with the inj pump gear drive set to TDC, just like you're going to set the valves. then you mark out 120 degree marks around the damper marking off the inj gear TDC. bingo you have 2/5 and 3/4 TDC. I'd use the factory valve spring tool if at all possible, it looks slick. 4 at a time.
Old 09-22-2007 | 05:54 AM
I SPEED's Avatar
Thanks for the info...I'm doing the springs today.
Old 09-22-2007 | 06:55 AM
AlpineRAM's Avatar
When I do stuff like that I usually pull the injectors and do not have nayx compression issues while turning it over and a short piece of wire makes it extremely easy to check that the piston you want to work on is at TDC. If you try it with the companion method you can still be some degrees off (doesn't matter for valve lash with a stock cam) and this can let the valves drop just far enough to get you into troubles installing the springs.
I must suggest that while ou are at it to install a new set of valve shaft seals.
HTH
AlpineRAM
Old 09-22-2007 | 09:18 AM
schoust's Avatar
Who has done this on a 12 valve?
Old 09-22-2007 | 05:02 PM
I SPEED's Avatar
I did this today...not too bad. Only trouble I had was doing 5 and 6 due to there location under the cowl. Frustrating not being able to see.
Old 09-22-2007 | 07:30 PM
schoust's Avatar
Nospin Was it a 12 valve that you did it on??
Old 09-22-2007 | 09:24 PM
I SPEED's Avatar
No, I did this on my truck.
Quick Reply: Valve springs....
