Valve Springs?
Helps control the valves better than the factory springs. Stronger spring rate and so on and so forth. Member Rowj picked up a fairly decent amount of torque after installing them due to him floating the valves at high boost. Don't need any requirements to run them. You can run them on a factory engine if you want to. But you really wouldn't see enough of a difference to warrant the cost. When you upgrade to a bigger cam or are pushing some very high boost numbers then it would be worth it to get them.
Thanks Ron, but I have one on the way. I am going to try to post some good pictures of the whole spring change.
Bigblue, What kinda boost numbers are we talking about floating the valves at? I run 65psi on the street, but only saw 50psi on the dyno.
Many 24v 5.9L Cummins experience piston slap and valve float over 45-50 psi boost: also exhaust soot build up in the air intake plenum!
IMO, F-1 valve springs are worthwhile and produce much better breathing above 2500 rpm.
Link to great discussion on these springs HERE
-Development of F-1 springs by Don M - Post #32
-"Are they needed" by HOHN - Post #51 & #53
RJ
RJ
I'd say your the perfect candidate for them. I'd like to put a set on my truck since I'm at 50psi but can't afford it right now.
BTW, per F1, 3100 is as high as you should tach with stock valve springs on the H2 cam so you don't float a valve.
Jordan5687
01-29-2015 10:32 AM
53 willys
23
05-19-2008 06:14 PM
12valve
03-11-2008 10:57 AM
95turbo4wd
12-12-2007 05:59 PM
