valve lash?
valve lash?
For all of you that do our own wrenching,what do you set your valves at?
Ive heard that .008 int. and .018 exh. on a hot engine is the best setting.
Also been told that .010 and .020 on a cold engine is the best.
What do you all think?
Thanks All, Mooseman
I set the valves at .010 and .020 every time. for accuracy of setting I use the cummins 6 inch-lb t handle torque wrench when doing the set. this ensures uniform setting across the board.
Just my oddball little way of doing things. good luck
REDNECK-WELDING
04-04-2008 06:06 PM
