valve body or transgo shift kit
Really don't know about the DTT valve body, but I went from a transgo, to a Georend Bros. valve body and there was a lot of difference. Very happy with transmission now.
Originally posted by 67HotRod
CTD NUT, can you give us some before and after info on the Transgo kit?
Check out SMR transmissions, they make a nice shift kit.
http://smrtrans.tripod.com/smrtransm...tro/index.html
I've done Trans-go kits for years and put one in my 02 truck soon after buying it.
I felt it was a cheap easy way to go. Also , later did the DTt up grades. It took me several tries to get the shifts were I wanted them and also the shift quality the same for each change of gear.
I then built a DTT trans for a friend and we used their - DTT - VB. He has a better set-up. If I was doing it again, and I will, it would simply be a DTT.
They set them up on a machine so there is very little changes needed for the tranny to work correctly.
Diesel Transmission Technology - www.dieseltrans.com
I did the valve body, servo and accumulator and am delighted to say the least about the way everything was set up and the support with questions.
I followed the directions, and hav'nt had to touch a thing. shift points are right where i want them and firm. not bark the tires, drop a driveline firm, but just right. And by the way, I have only seen my trans temp hit 160 once. that was in town driving with 12k. otherwise normal driving is 110-120 degrees.
And no i dont work there or know anybody that does, just a good product.
I did it myself , took about 4-5 hours. Its pretty srtaight forward with good directions. If you have any questions, as i did, you can always contact them while in the process and they'll walk you through it.
shrmpboatcptn
11-16-2010 06:46 AM
shoe
02-14-2006 04:48 PM
Bobcat698
07-24-2005 09:24 PM
dansdodgediesel
11-28-2003 09:17 AM
