Valve body install
Valve body install
I am planning on doing a BD valve body this weekend as soon as i get my new 10000# Rotary lift installed SAt.
Is it really necessary to take the pressure readings & shift points before hand, if so how did you get the pressure readings?
You should measure the pressure with a pressure gauge and a long hose (say about 8 feet or even longer). There are, I believe, 3 ports on the passenger's side of the tranny that you tap into. Each one serves a different purpose. Measuring the pressures helps set up the VB properly and make sure you don't have any internal leaks.
12ValverDave
11-15-2008 03:50 PM
Tedonlin150
02-24-2008 11:50 PM
Billwie
12-23-2007 11:42 PM
Megaramasaur
05-25-2007 11:02 PM
