valve adjustment?
Old 04-04-2008 | 10:42 PM
dodgetrucker75's Avatar
valve adjustment?
i have heard some people talking in the past about adjusting there valves differently for gains... all i remember them saying was to take the exhaust valve down to 0.015. are there realy gains from this? are there any other combinations of adjustments? what are the pros and cons? even worth attempting? let me know what you think.
Old 04-05-2008 | 02:33 AM
blueboy16's Avatar
i have never hers of anything like it but i had some bad things happen from valves being out of adjustment like the rocker bolts stripping out the holes. its not a good feeling to hear that sound
Old 04-05-2008 | 12:26 PM
oscaroc's Avatar
I have heard of it, but couldn't find enough info. to feel like I was gaining anything. I just adjusted mine to stock spec, and I believe the 5 & 6 exhaust valves were out of adjustment. It made a small difference in sound at idle, but other than that I didn't notice much
Old 04-05-2008 | 01:21 PM
BC847's Avatar
1st Generation Admin
As I understand it, by running tighter clearances, you in effect lengthen the duration of the valve being open. The gains are very small at best (if any) and obviously you run closer to the point of . . . . "Uh Oh! What's that sound!?"
Old 04-06-2008 | 02:53 PM
justme-'s Avatar
Tighter tolerance can mean not enough expansion room when at temperature, or running under high load or high rpm. Use the factory specs. The potential theoretical gain is not worth the risk.
Fishbait
11-23-2009 12:21 PM
ConnerCop
05-05-2009 08:48 AM
dhughe2
13
12-06-2006 08:40 AM
bulthisl
03-22-2003 08:01 AM
blackboat
11-08-2002 07:32 PM
