upgrade yes or no
Old 02-27-2003 | 06:37 PM
ox's Avatar
ox
upgrade yes or no
i have had my dodge for a while and i can't stand it anymore. i want to put a chip in but the problem is that i have 66000 mile on it will this hurt it ???
Old 02-27-2003 | 07:11 PM
TPilaske's Avatar
Re:upgrade yes or no
Throw an EZ on it, that'll liven it up a bit... ;D<br><br>Tony
Old 02-27-2003 | 07:28 PM
Dieseldude4x4's Avatar
I put an EZ on mine at over 100000 miles. Don't do it. You will never be able to get the grin off your face. And that's only the beginning. Remember, you've been warned. Once you start, you can't stop.
Old 02-27-2003 | 09:35 PM
NAIL BENDER's Avatar
[quote author=dieseldude4x4 link=board=7;threadid=11574;start=0#109912 date=1046392086]<br>I put an EZ on mine at over 100000 miles. Don't do it. You will never be able to get the grin off your face. And that's only the beginning. Remember, you've been warned. Once you start, you can't stop.<br>[/quote]<br> I did the same at 74000 mi and like dieseldude 4x4 said, It's only the beginning and it leaves you wanting more.
Old 02-27-2003 | 10:00 PM
OlBlue's Avatar
I STARTED with my 1st gen at 100,000mi. 135,000miles later, NO problems unless you want to include:
Lotsa smiles from me
Old 02-27-2003 | 10:36 PM
John_P's Avatar
ox:<br><br>If you install the Edge EZ Fueling Box and have an<br>automatic transmission I highly recommend at least<br>installing a shift kit or aftermarket valve body to raise<br>the line pressures some.<br><br>I friend of mine down here has a 2001 Dodge CTD<br>with the auto and after three months with the Edge<br>EZ his transmission is already starting to shudder <br>when it goes into 4th gear (lockup).<br><br>--------<br>John_P<br><br>
Old 02-28-2003 | 12:34 AM
This is what happens when you start bombing. <br>As you can see, JohnP's truck definately has a traction problem here. When you want to go for a ride and see what this little six will do, give John a call for sure.
Old 02-28-2003 | 03:01 PM
Hired Gun's Avatar
I bombed mine at 65,000. I love to smoke up the highway. Listen to DieselDude. Smile from ear to ear.<br>Be prepared for therapy though. Its like other addictions.
Old 02-28-2003 | 03:55 PM
TPilaske's Avatar
C'mon now.. it's not that addicting! : The only thing I want now is a bigger turbo! ;D<br><br>Tony
Old 02-28-2003 | 07:19 PM
John_P's Avatar
dieseldude:<br><br>Thanks for taking and posting that picture! We sure<br>had fun that day! ;D<br><br>-------<br>John_P
Old 03-01-2003 | 12:16 AM
Got Smoke?'s Avatar
[quote author=dieseldude4x4 link=board=7;threadid=11574;start=0#110042 date=1046410499]<br>This is what happens when you start bombing. <br>As you can see, JohnP's truck definately has a traction problem here. When you want to go for a ride and see what this little six will do, give John a call for sure.<br>[/quote]<br><br> :'( :'( :'( :'( :'( :'(<br>That HAD to have been taken after I left that day! why did I have to miss that? :'(<br><br><br><br><br><br><br><br><br><br>
Old 03-01-2003 | 03:32 PM
Racer57's Avatar
Assuming you have a 24 valve, add fueling box. I recommend going straight away to an Edge Comp or its equivalent. Leave the pump wire dangle. Do your research, don't forget gauges and drivetrain, and after you have driven your truck awhile, then hook up the wire and it will feel like driving a new truck all over again.<br><br>Roger
LilBigd02
02-28-2007 09:31 PM
vegasbound
14
10-13-2003 02:46 AM
