Unplugging map sensor with J/A
I know with the comp boxes you could unplug the map sensor and the truck would run fine. Can you do this also with the Juice with attitude? I just installed one on a buddy of mine's truck and he was wondering if he could unplug the map sensor and still run fine.
when i unpluged mine i couldnt build any boost at all with the stock injectors. i herd you have to short out 2 of the wires for it to work ok and smoke like a mother.
I did it, heres the post https://www.dieseltruckresource.com/...d.php?t=137629
if it is a older or original juice attitude for a 03 it will work just unplug the map and the coal will roll I have done it with my own two hands but you will not have accurate boost readings on the monitor
Isn't the stock fueling aggressive enough on 5x5?
Sorry, but I don't see the need for fiddling with the sensor unless you like belching black smoke and giving us all a bad name
Just buy the 100 dollar HOT upgrade, ie Drag version, it will fuel harder with the map sensor intact than 5x5 with a jumper plus you get revs up to 3400 or so, at least mine has recorded revs up to 3420, it seems to defuel slightly around 3200 but with jammer 5's it's hard to tell.
smokinstrokes99
11-08-2007 10:02 PM
Big Deezul
17
12-19-2005 06:12 PM
BigBlue
58
11-17-2005 12:41 PM
