Unplugging the Map with a comp
#31
Originally Posted by BigBlue
CTD NUT, I wonder if the factory ECM defuels on the bottom end with the 5spd. If it doesn't, then that could explain why your not noticing as big a gain.
zukgod1, I wonder if your tighter TC makes a difference?
#33
Well yall did it to me! You made me do it after reading this thread. I was going to settle for a cheaper box but today i had to order the Edge Comp and i got a good deal on the box too. So soon i will be having as much fun as yall are having. Can't wait to be smoking like a train. Thanks again for making me spend more money! Jamie
#35
I don't know if the wire has to be tapped or not. Only one way to find out I guess. I just unplugged my roommates map and we didn't notice much of a difference. Lots more smoke but not much bottom end. His is an 01 HO 6spd with mach 1.5's and a drag comp. Dynoed 401hp.
#36
it does the same with an ez as the comp, maybe a little less smoke, but basically the same results, never tried it with a comp & no wire tap, but I would imagine it should do the same as the ez. I also have only done this to 5 & 6 spd. trucks, don't know about the results of doing it with an auto??
#37
i did it tongiht with my 6spd...same as everyone else, LOTS of smoke, no codes or check engine lights, and maybe a little kick in the pants when you first touch the throttle but its a little harder to drive smokeless with it unplugged.
i love that in neutral or with the clutch pushed in, you can rev it from idle and a big long puff just comes barrelling out. will be fun to mess with some guys in parking lots with that. but i think for the street i will leave it plugged in as i do not wanna smoke too much and get pulled over by The Man in Blue
#39
Originally Posted by bentwings
It would be nice to make up a little harness with a switch on it so you could do it from the cab.
Originally Posted by SuperDave4x4
That is exactly what I have thought about doing, putting a switch on it. Now If I feel like being a jerk all I have to do is flip the switch.
#40
The unplug mod does produce more bottom end on my truck. It also kicks the 236 code (map sensor to high to long). Will this hurt anything? If not I believe Ill leave it unplugged for a while.
Mooseman
Mooseman
#41
Anyone notice how different the engine sounds at low rpms? Mine sounds alot different. Also I have a noise that sounds like the engine is missing on the freeway, about 1900 rpm in 5th gear, when I put a slight load on the motor. Anyway with the comp unplugged the noise is all but gone. Maybe I have a bad map sensor. Definately has more smoke.
#42
Just installed my Edge Comp today. Never even plugged in the Map Sensor. Does it Smoke? Yes! Am i happy? Yes! It really woke the truck up. Very fun to drive now. Althought i am not sure how it will improve fuel mileage? Cant seem to keep my foot out of ithe gas!.......................Jamie
#44
Okay, I had to try it, my Comp is un-tapped and with unplugging the map the power now comes on smoother and the throttle response is definatley improved, but the greatest part of all is the pretty cloud I get when hittin it from a dead stop I even get some smoke from roll if im low enough in the rpms, thanks for the tip it definatley works.
#45
Originally Posted by 99purplecummins
as i told tyler, keep the smoke down or you won't be able to do it in the future. they have restriced the big rigs and we are next.
remember we are like muscle cars of the 60's. the EPA killed them and they can kill these trucks just as quick
