Unhooking The Map Sensor
Old 04-10-2006, 07:44 PM
STACKED's Avatar
cool thanx.
Old 04-12-2006, 02:15 PM
1st gen Hobie's Avatar
Would a stock 2001 make smoke with a boost fooler and un-hooking the map sensor?
Old 04-13-2006, 06:23 AM
I SPEED's Avatar
I was at the track last night and made a couple of passes with the map plugged in, then I unplugged it and made a couple more.
Made absolutely no difference in performance or smoke.
Old 04-13-2006, 12:21 PM
01smoker's Avatar
Make sure your box is on when you unplug it from the MAP sensor. Mine was plugged in and I drove up to UPS to ship my comp off for the drag upgrade and I simply unplugged my box from harness and shipped it off. When I got back in my truck and took off, the check engine light came on and it had NO power AT ALL. I guess it went into limp mode. So I went home and disconnected the battery cables for about 15 min and then connected them back up. It Ran like normal then but the check engine light was still on. I just had a friend clear it with his code reader.
Old 04-13-2006, 02:05 PM
singleturnout's Avatar
i think mine smokes more because i have some stage 5's
Old 04-13-2006, 02:32 PM
I SPEED's Avatar
Ya think?
1. The message you have entered is too short. Please lengthen your message to at least 10 characters.
I just did...
smkn97s
01-12-2007 07:06 PM
smkn97s
01-12-2007 06:50 PM
mx684
01-01-2007 11:38 AM
Dusty Ratcliff
05-28-2005 11:51 PM
00turbo
09-03-2004 06:53 AM
Quick Reply: Unhooking The Map Sensor
