unhooked map nothing happen
i unhooked the map sensor and nothing happen. the smoke was the same not any more. is there anything else i need to do or unhook when i unhook the map to get more smoke?
fill in ur sig. if you don't have a comp box then it won't work, if anything it will run worse, but if you have the comp then I believe you unhook the plug that goes into the map sensor & leave the factory map sensor plug connected to the comp's wiring harness, that's what I'm thinkin anyway, it's been awhile so someone correct me if I'm wrong????? hope this helps, Dusty
You won't mess anything up. I've been running around like this for months now. The main benefit is smoke but one guy dynoed and got an extra 10-15hp and about the same torque. I noticed a bit more bottom end on my truck when I undid it.
Originally Posted by 1998dodge
is there any other place to unhook it at that will make it work? i unhooked it right at the block and nothing happen no code come up and no more smoke.
Originally Posted by EGaskamp
I didn't know you had your map sensor unplugged Tyler. I'll unplug mine and put the stacks on and we could make it look like CS is on fire!
Eric
Eric
