Two speed rear end switch clamp
I am going to put a two speed rear end switch on my truck to run the jake brake. What kind of clamp do I need to use to mount it to the stick and where can I get it. Pics of other rigs would be nice. Thanks.
You might want to try junk yards that have the bigger trucks, and see if they'd happen to have one from a 2 speed axle equipped truck.
I looked when I put mine in, but couldn't find any, new or used. I ended up making my own bracket out of a chunk of aluminum, at a machine shop where I once worked.
I see that Geno's Garage has a replacement E-**** gearshift **** with a micro switch built in it to run an E-brake for $49.
Our bobtail at work just uses a hose clamp...not the greatest looking, but it works. Either that, or use an Eaton Fuller shifter that screws onto the stick. the threads don't match, I drilled thru the guts to make mine work (dont have an exhaust brake), but I'm sure it could be done.
Bad Ramer Jamer
12-27-2007 10:32 AM
