Two More Smarty Questions
ok short and sweet...
1) does SW 1 fuel saver actually work?
2) the turnbuckle wastegate mod. does it still work with the smarty as it did with the ez?
its less aggressive and easy on the tranny shifting wise JMO. sw#5-9 are all to aggressive for a slipping tranny.
i think the mpg gains are very diferent to which mods you have and how the smarty reacts to your truck,i never seen any gain on fuel saver mode but i did see at least 2 mpgs on#9.i think fuel saver has some extra fueling with the timing that defeats the "saver mode"i would like to see a agresive timing with no added fuel mode for a true fuel saver.all the softwares in the smarty have the overboost,fuel cutoff deleted so you may see some benifit to getting a turnbuckle or disabling the wastegate all togwether,i disabled mine and i can get her to well over 30 without the comp,with the comp i can peg my 40psi gauge.
ya i hear ya on that! i think i'm gonna end up doing that cause i don't wanna smoke my trans too early. not really a good time for that right now, ya know what i mean? so i asked in another thread but i didn't get an answer yet but it was, does DTT etc. finance trannys, or would i have to take a loan out? anyone know?
duallydave, i think your right about the mpg gain with #9 over #1.
after a few more tanks i will post my mpg calculations over the last few months. even though i use more boost accelerating on the higher levels, i still think im getting better on sw#5 over sw#1. i guess only my calculations will tell.
My best milage has been on sw9. If I get 1/2 mpg better going to sw1 its not worth it to me =P Sw1 would still smoke my stock clutch though. I've yet to try sw0
I'm waiting on my gear right now......I hope to pull better mileage. actually I'm going to like the tire height adjustment to correct my computer better......so I can get an accurate mileage #
and i'm just curious on how the SW1 will compare to my EZ i had in mileage gains. should be interesting. lots of playing around you can do with this thing.
My speedo is accurate for my 35's when set on 34.25"!
RJ
and to avoid further confusion....when I said correct my computer I'm talking about the ECM for speedo and odo correction not an overhead computer.....I don't have an overhead computer. My truck is base model, manual everything. except cruise.
you've gotta point...sorry bout that...i just wanted to sound smart
