Twins v. Compounds
Mod your AFC for full travel, then move it rearward. You will get more rack travel, and be able to keep it cleaner.
Unless he is encountering spring bind in the AFC, the starwheel does not affect full fueling. Starwheel will affect when the afc foot begins to move, since it changes the amount of preload on the diaphragm.
As does the spring he runs. Run a light spring with lots of preload, a medium spring with less preload, or a heavy spring light preload. All could start moving at the exact same pressure, but the light spring will obviously hit full fuel first, heavy spring last.
Hes running a HX35/40.
We all know anything above 32psi is starting to get out of the efficiency range of an HX35
4969joes
01-14-2012 12:00 PM
Stock 02
28
09-24-2006 12:09 PM
trik396
07-26-2006 03:47 PM
