Twins with a stock turbo?
Old 10-08-2007 | 12:14 PM
  #46
5.9Excursion's Avatar
Just the small unless you are planning on spraying nitrous. Then you may have to wastegate the large too, this would prevent overspinning it...
Old 10-08-2007 | 12:15 PM
  #47
JIT's Avatar
JIT
What if you're using water/meth?
Old 10-08-2007 | 01:03 PM
  #48
dieseldork's Avatar
Hey 5.9 Excursion how did you support the weight of that bottom turbo I don't see anything in your pixs or is it just hanging of the top turbo .
Old 10-08-2007 | 05:41 PM
  #49
It's just been hanging... A bracket would be better I suppose, but this is how they came to me and I haven't had any probs...
Old 10-08-2007 | 06:52 PM
  #50
Dodge359's Avatar
Mine has no bracket either. I couldnt find a good place to hang one.
Old 10-08-2007 | 06:57 PM
  #51
Pinkston's Avatar
How much does the larger bottom turbo generally weigh? I would think just hanging off the top turbo would put alot of extra stress on the manifold and possibly crack it. I guess it is some what supported by the downpipe and exhaust hangers though.
Old 10-08-2007 | 07:29 PM
  #52
dieseldork's Avatar
Now for my dumb question so don't laugh could a person use a HY35 as a top turbo to just get my htb2 62/14 on the bottom going a little faster ? just curious I guess .
Old 10-08-2007 | 07:32 PM
  #53
HOHN's Avatar
You could, but the gain wouldn't be significant-- you'd probably be lcuky to end up with the original spoolup of just the 62/14.
In other words, all cost, no benefit
Old 10-08-2007 | 08:38 PM
  #54
Dodge359's Avatar
The bottom turbo weighs in at better than 50 pounds if I had to guess. They are all different.
Has anyone ever broke a manifold from the weight??
Old 10-08-2007 | 08:51 PM
  #55
Dodge359's Avatar
Originally Posted by BigErksG2
dodge359... thats what im looking to do. how did you oil the second turbo? run a line from the first turbo to the second and then to the return?
1st pic is a picture of what HOHN was talking about. (oil feed)
Oil in is the easy part, oil out (drain) sucks. I'll bet a shiny nickel you dont have the boss cast into you block that works as an oil drain. I had to drill/cut my pan and plumb a drain in. (2nd pic)
Attached Thumbnails Twins with a stock turbo?-img093.jpg   Twins with a stock turbo?-080407_19331.jpg
Old 10-08-2007 | 08:52 PM
  #56
1320's Avatar
You dont have to waist gate the small either, but its recommended. I ve been running with NO waist gate at all for three years. My current endevor is to ad a 50 mm gate to the small turbo and replace the 35, with either a 35/40 or super 40. I like the idea of the super 40 but am afraid it will spool slow, esspecially with a 16 cm housing.
Old 10-08-2007 | 09:01 PM
  #57
Dodge359's Avatar
1320, whats the difference between a stock 40 and a super 40?
I am also running w/m and had no problems. I was told once to keep the HT3B at 30 psi or less??? HOHN, anything to say on that?
Old 10-08-2007 | 09:03 PM
  #58
Why_Try's Avatar
How is it changing your filter with it in the stock location. Most of the setups I see have a remote oilfilter...I'm assuming because of lack of space.
Old 10-08-2007 | 09:09 PM
  #59
Dodge359's Avatar
Changing the filter is a test of mental fortitude and of your knowledge as it pertains to four letter words. A remote filter is in my future but I havent found one I like.
Old 10-08-2007 | 09:15 PM
  #60
1320's Avatar
The super 40 is what pdr selld I guess. They make claims in there stuff but who knows, thats why Im hesitant to tru the super 40 as a small turbo. Im afraid it just wont spool fast enough for towing. Maybe it would be great though.....
My 12 v had another plug in the top of the oil filter housing , all I had to do was put the fitting in and oil to the second turbo. The drain was super easy but I had the plug at the bottom of the block. took the plug out , "right stuffed" a piece of brass pipe in (3/4) and my drain from the big turbo goes straight down about 6 inches maybe on the the 3/4 inch stub.
The only reason I even redoing my small turbo is , my hx35 is bit chewed up, and I guess it would be a good idea to try to limit its over speed condition, although so far it hasnt cared. I ve never heard to limit a ht3b....mine only make 60 psi with no waist gate, I figure I might make more with a gate on the small turbo, or just lower the egt, or just slow the little one down a bit.
As soon as get a replacement turbo ll be doing it.
