View Poll Results: What Color to coat twins piping
Same Blue as boots (Bright Blue)
13.33%
Midnight Blue
30.00%
Black
20.00%
Red
23.33%
other (specify)
13.33%
Multiple Choice Poll. Voters: 30. You may not vote on this poll
Twins Questions and Color Choice!!
Old 07-13-2006, 10:33 PM
bnold's Avatar
Ok I just recieved my Twin Turbo kit in the mail today from Source Automotive . I got the kit that is unfinished, so I do my own welding, grinding, sandblasting, and coating.
Question is What do I all coat?
Can I coat the hot pipe or will it get too hot, exhaust manifold??, Can I do the intake horn??
As far as the poll goes what color should I use?? The boots are a bright blue, truck is white. I dont really want it to "blend" in (for the cost I want it shown!! )
Old 07-13-2006, 10:49 PM
BigBlue's Avatar
Midnight blue would be awesome and I think it would offer a great contrast.
Old 07-13-2006, 11:33 PM
msing's Avatar
I used POR 15 to paint the hot pipe, turbo exh. housing, and manifold and this stuff stays on its been 6 months and 8000 miles looks like the day I put it on. As for the cold pipe IMO paint it blue that matches the boots.
Old 07-14-2006, 12:38 AM
Munchies's Avatar
How much for the unfinished kit if I could ask?
Old 07-14-2006, 12:49 AM
Jambbii's Avatar
I have red inducer housings and HPC coated exhaust housings. Check my gallery for pics.
Old 07-14-2006, 01:43 AM
hotmopr's Avatar
You really should heat wrap the hot pipe so It wouldnt matter what collor it is. As for the cold pipes I went with a hammertone paint that is dark gey with the blue boots and blue powder coated valve covers. I still want to do the alt bracket the same color blue along with the heater lines etc.. Then I want to blast the air horn to match the compressor housings..
The colors of the valve covers are closer to matching the boots than the pict shows..
Old 07-14-2006, 06:04 AM
Tiger Rag's Avatar
AK Ram painted his exhaust housings on his turbo's and the exhaust manifold with the previously mentioned POR paint. They look like new still. On the cold pipe, if you want to show them off, you could have them chromed.
Old 07-14-2006, 03:09 PM
joefarmer's Avatar
Very nice! One word of caution on the intake horn, the 12 valve intake horn appears to be made of a different substance than the 24 valve aluminum horn. It may just be a different alloy, but the aluminum used was definately a harder material that didn't polish very well. I ended up powder coating the intake.
brnaodn.
Old 07-14-2006, 03:45 PM
bnold's Avatar
Wow those look really good what kind of paint/coating is the red??
Old 07-14-2006, 03:46 PM
bnold's Avatar
As far as the POR coating goes I imagine I would need to go with a high temp blend. Is black and grey all that is offered?
Thanks for the info guys this is exactly what I'm looking for!!
Old 07-14-2006, 03:51 PM
bnold's Avatar
I believe shipped to my door (very quick I may add, was impressed) $2900 that included the tacked together pipes (some were completely finished) and a 14cm housing for my 35.
The kit seems to be very complete and of good quality. I talked to the guy and quote "we design these kits making sure you never have to run to the hardware store in the middle of the project, all the little pieces are included"
ok so that quote is not exact, but somewhere along those lines!!
I'll try and lay it all out tonight and get a couple pics to post
Old 07-14-2006, 04:55 PM
paulb's Avatar
Congrats on your purchase! My cold pipes are powder coated a spackel dark gray. I have not coated the hot pipe, but I have it wrapped. I have seen both the POR and Jet Hot coated pipe. I think I am going to do the Jet Hot, on the outside of the pipe only.
Paul
Old 07-14-2006, 05:07 PM
Rodram2002's Avatar
I think the Midnight blue would be cool. Please tell how the install goes and how they perform. I just got the same thing. I wont be able to put mine on for a few months though.
Old 07-14-2006, 05:14 PM
bnold's Avatar
Will do! will prolly be welding, grinding, blasting away this weekend then to figure out what coat, paint, whatever is going to work and look best!!
Old 07-14-2006, 09:44 PM
bnold's Avatar
Bump up for the evening crowd!!
Quick Reply: Twins Questions and Color Choice!!
