twins oil drain
Which turbos you gonna run? Using two drains into one is abit risky IMO. you might flood the turbo and ruining the turbo seals, sending oil into the intake/exhaust. A ball bearing garrett uses a oil restrictor, so you might be able to get away with one drain.
Sourceautomotive seals a tap kit so you can add a second drain.
dodgediesel
17
04-05-2011 12:21 PM
Stock 02
28
09-24-2006 12:09 PM
