Twins are cooking...(hx35-16 and ht3b)
Old 09-11-2004 | 05:50 PM
1320's Avatar
I changed my hx 35- 12 to a 16 last night....and its much much better. I hooked up my 50ft enclosed car trailer and was impressed. I was passing people up a grade.
I still have higher then I d like egt's undoubtbly due to my timing. I need to raise it to 16 or 17. Pulling the hill with my trailer I was accelerating slightly in 4th (started at a stop) I could hold 1200 degrees @25 psi @60-62 or nudge it up to 1300 degrees @30 psi and pull up to 65-68 . Remeber this is with a 50 ft GN with two roof airs, awning etc...
Its pretty easy to keep egts under 1200 and still go enty fast enough. I past a guy in a chevy pulling a little 25ft ft..probably 15 mph faster then him on the hill, I swear he looked, then looked again as the trailer was going by.
Pulling 5th gear (354's) is much easier now too. I can go up slight grades in 5th at 65-68 no problem.
Going faster would be easy.
I love this truck.
Old 09-11-2004 | 07:08 PM
Forrest Nearing's Avatar
what size turbine housing do you have on the HT3B? what's your max boost?
thanks,
Forrest
Old 09-11-2004 | 07:57 PM
1320's Avatar
I don t know the max boost. I have had it running a grand total of two or three days now. The ht3b is a 26.
I think I ll back my #10 plate off a bit, maybe .030 or so. I m at 2500 ft, and the DA is ussually around 5000 ft. Just for reference, today pulling my trailer it was 95 degrees outside too.
Old 09-11-2004 | 08:10 PM
if you want to try a 22 undivided or 23 divided housing, lemme know, got a couple for sale
Forrest
Old 09-12-2004 | 11:47 AM
1320's Avatar
I have a question....I backed the #10 plate off a tad. About 030. I did notice that the housing also slides though? So I slid the housing back too. On a drive the egts seem to actually settle.....yea! around 1200-1300.....
I think alittle tuning with the plate housing and star wheel will do it.
On the down side I have advanced the timing yet.
not much smoke anymore....alittle but not like it was.
Old 09-12-2004 | 12:23 PM
sliding the plate back means less fuel... less power and lower EGT... if you're only getting 1200-1300 @ WOT, I'd give it MORE fuel! you can always keep the EGT steady with your right foot, but a quick blast over 1300 isn't gonna hurt.
I peg my 1600* pyro daily!
anyhow, sliding the housing back adds tension to the star wheel... less smoke and slower spool up.
Forrest
dodgediesel
ABDTR #5
10-18-2011 10:22 PM
dodgediesel
ABDTR #5
496
10-16-2011 05:33 PM
blackdiesel
29
01-05-2006 03:46 AM
Clucker
08-21-2005 12:00 PM
SjLingenfelter
29
05-17-2004 11:40 PM
